Help, I'm stuck on telus 3G.
  • Updated 2 years ago
Switched from telus pre paid to Koodo pre paied, still says my provider is telus and my data is not working. I'm able to text though.
Photo of Alex Hilder
Alex Hilder
  • 90 Points 75 badge 2x thumb
  • frustrated
Posted 2 years ago
Photo of Sophia
Sophia, Mobile Master
You don't have to worry about it saying Telus... I often get that as well.
As for data, did you add a data booster and have you checked your APN settings? http://help.koodomobile.com/plans-add...
Alex Hilder
I'm on android and the page is missing for Android instructions.
Alex Hilder
Thanks! Oneplus actually had me covered, it was pre set! Took some fiddling though.
Photo of Sophia
So you have data now? Sometimes it takes a reboot too, but glad you got it all sorted :)
