How can I change my cell number to a local number ?
Photo of Tanya Duguay
Tanya Duguay
Photo of Jonathan I
Jonathan I, Mobile Master
I don't know 100% if it's possible on prepaid but if you are registered for Self Serve then the option will be there somewhere. Otherwise, you can call customer service and have them do it.
Photo of Tabby LaBonte
Tabby LaBonte
  • 60 Points
Self serve would be free, but I don"t believe that if would cost you anything, if you are moving to another province if you called in.
