HELP!!!
I have the Apple I Phone 4 or 5(can't remember which) and sometime last week all of my contact info seems to have been wiped out. All I have left are 14 contacts. Also, in calling history I have all the phone numbers but the name attached to the number has been wiped out(assuming it has something to do with the contacts all having been wiped out). Does anyone have any idea why this happened and how I get the contact info back?
Photo of Leslie Kipling
Leslie Kipling
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Robert
Robert, Mobile Master
  • 103,372 Points 100k badge 2x thumb
If it's an iPhone 4 it is supposed to me smaller and iPhone 5 bigger and more rectangular.
For your problem, did you recently make a restore? Remove an account from the phone (hotmail, google mail, etc)? Did you change SIM cards?
Photo of Dennis
Dennis, Mobile Master
Or maybe it is restoring right now and it takes time to load everything from icloud.
Also check
Settings>Mail, Contacts, Calendars
Make sure you have signed into your icloud or gmail, etc where you originally saved your contacts.
If you saved your contacts just to the phone itself, then Settings>iCloud sign in and restore from backup
Or if you backed up via itunes just plug in tyour computer and restore from back up.
Photo of matthew sider
matthew sider
  • 746 Points 500 badge 2x thumb
Did you clare all runing app in back round
tray software reset if you done that if nothing improves
call kood you may wanna send your iso device in for warranty here app may clean master helps your phone working well make shour you did updates
Leslie Kipling
Thanks for the distinction between phones. I have the iPhone 4. I have done none of the things you suggested. I have cleared all apps in background running, did a software reset and nothing changed. I will call Koodo Support. Thanks for the help!
Photo of Robert
Koodo support will not be able to assist you with your problem. They could try, but my suggestions is that you should go to an Apple store (they will see the phone with you and may provide physical help). You'll get the most rapid answer there! Find the nearest one near you (https://www.apple.com/ca/retail/) and take an appointment!
Or go here : https://getsupport.apple.com/Getprodu...
Photo of Matthew Sider
Matthew Sider
  • 2,432 Points 2k badge 2x thumb
Hello Robert only problem apple charges for everthing koodo should be able help
is litte dumb that koodo won't help people with apple divce iPhone can you please help me to understand thanks robert
Photo of Dennis
Yes Robert. Please help Mr.Sider
Matthew Sider
There are to things 1 way you cant go koodo for help with your apple iPhone I'm hereing you have go to apple store thay charge for everthing if you don't apple care is litte incvent don't you think
2 I got android phone note 2 gealexy phone
would there up date for this phone little buggy
because goolge hade bugs in there software
thanks Robert
Photo of Yannick
Yannick
  • 43,998 Points 20k badge 2x thumb
Hi Matthew, we can indeed help for the first troubleshooting! If the issue is still not fixed, a customer would then have to check with Apple directly http://koo.do/WQ37a0. Thank you :)
Matthew Sider
Okay you cleat all the running apps you may look for clean master it kills unwanted apps in the back round
Boost your phone if that didn't help may be your software if under warranty send in kood
now please make shour you have warranty
if not apple won't look at untell you bye apple care
greddy of apple but this way I have
thay would look at it please make sure you did updates
charged battery
Photo of David
David, Mobile Master
  • 88,962 Points 50k badge 2x thumb
Were you mirroring your contacts from anywhere? The iPhone can have contacts from a number of sources. For instance, some could be on your phone, and some associated with a Google, Yahoo or other email account or similar. Is it possible that you have disconnected one of the locations where contacts were stored by deleting, removing or disabling an account?
Do you have a backup of you phone either on iCloud or on your computer via iTunes?
