help I cant send text messages on my huawei ascend y330
  • 2
  • Updated 2 years ago
I for some reason cannot send text messages on my huawei ascend y330, I can type out a text message no problem but when I go to hit the send button the send button is grayed out, and also when I go to turn it on my phone says it has no SIM card in it even though it has a SIM card in it
Photo of Kyle Keagan
Kyle Keagan
Posted 3 years ago
  • 2
Make sure you're not typing your message where the recipients phone number is supposed to go.
Are you able to make calls?
Photo of Senior B Bube
Senior B Bube
  • 60 Points
Yes i can make a call, but in message menu doesn't work, i cant send or receive message form my contact
Photo of Carol Kenny
Carol Kenny
  • 82 Points 75 badge 2x thumb
I can receive messages, I have 6 non sent massages with a triangle in red with an explanation markĀ
Kyle Keagan
Yes I am able to make calls
Photo of BobTheElectrician
BobTheElectrician
  • 61,576 Points 50k badge 2x thumb
Pull the battery (if feasible) and SIM card out, gently clean SIM contacts with a pencil eraser, wait 15 minutes, re-assemble and re-start phone.
Sounds like an issue with the SIM. Was this phone/SIM provided by Koodo as an original purchase or did you bring your own phone and just buy a SIM from Koodo?
Still under warranty: *611 or visit a boutique to swap out the SIM.
Kyle Keagan
Yes I bought the phone and the SIM from koodo as a prepaid phone
BobTheElectrician
Every single prepaid plan includes unlimited text messages, so it's not as if you've bumped your head on a limit ceiling.
Did you try my SIM/phone reset suggestions above?
Can you actually send YOURSELF a text successfully?
