My Nexus 5 just shut itself down and now I can't turn it on
  • (Edited)
hi i was talking to my daughter when my nexus 5 did a shut down and now i have it pluged in for 2hrs and it will not open can you tell me what to do thanks
Photo of joanne
joanne
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Mitchell Palmater
Mitchell Palmater
  • 12,996 Points 10k badge 2x thumb
If the phone wont turn on after a charge of 2 hours unfortunately that's it =[
If you are sure the charger isn't the problem (can you see charging light?)
If the phone is less than a year old, you can get it repaired for free under warranty as long as there is no physical or water damage.
Otherwise it's time to shop around for a new device!
Photo of joanne
joanne
No that is not the write answer I held the volume button and the shut off button at the same time and it started that is called a quick restart.
Photo of Spence
Spence
  • 8,354 Points 5k badge 2x thumb
Great,  good job. Glad its working.
