help
i tried to top up my account with credit card..my phone doesnt work..it shows it did on my account but yet i cant message or call
Photo of Donna Reekie
Donna Reekie
Photo of John Lee
John Lee
You top up'd you base plan or boosters? The base plan has unlimited texting, caller ID, voicemail, etc. So if you only have a base plan; then you can only text unless it's one of the $25+ base plans that include unlimited evenings, then you have to wait until those evenings come (7pm, 5pm, etc).
If you have boosters, then you can access calls and data. If it just doesn't work on your phone, are you sure that you have the correct SIM card? That it is Prepaid SIM?
You can also try a battery pull, which is taking out your battery and your SIM card for 30 seconds - 1 minute and then retrying again.
If all fails, there may be an issue with your cell phone. What phone do you have? Is it a Koodo phone?
Photo of Angela
Angela
  • 488 Points 250 badge 2x thumb
Sometimes all you have to do is reset ur phone for it to register that you just topped up ur account so just shut the device off and power it back up usually that fixes the issue hope this helps
Donna Reekie
how do i shut off my phone
Donna Reekie
i have a koodoo phone..how do i shut it off..new to this
Donna Reekie
it worked thanks
