HELP DATA WONT WORK WITH LG V20 URGENT ASSISTANCE
  • Updated 1 year ago
I recently signed up with Koodo, from Freedom I have an LG V20 (H915) model, calls work but no data cant get on the internet.  Set koodo apn and made sure it was selected but nothing.  Took it to Telus and I was able to get their sim to work data and cell, went back to Koodo tired different sims no luck.  I was told by Koodo rep that Koodo has not made their service available to LG V20's
Any ideas or help greatly appreciated.  I tested my phone on Bell, Telus and Rogers they all worked after imputing APN info, but not Koodo.  I want a Koodo plan though
Photo of George
George
Posted 1 year ago
Photo of Goran
Goran, Mobile Master
  • 97,738 Points 50k badge 2x thumb
There is nothing about the V20 that would make it not work with the V20. This is odd tho. Which APN settings are you using? Did you try a different phone if you have one? It really makes no sense for a couple koodo Sims to not work after adding APN settings. If at all possiblee try with another phone.
Photo of rikkster
rikkster, Mobile Master
  • 68,380 Points 50k badge 2x thumb
Have you tried resetting network settings, George? Go to Settings > Backup and reset and scroll down to Reset network settings and follow the prompts.
