help : Confused to purchase a compatilble phone
Hi All
I would appreciate your advices
I am going to buy a new phone, not gonna to shop from careers, and use TAB, I really care about a phone features, so I am using this phone finder
http://www.gsmarena.com/search.php3
but please advice me, what network should I select to get compatible phones with koodo or Chatr or Wind
I have heard it must be 1700/2100 , but I when I drill down the 3G/4G networks ,There are many options that make me really confused
what should it be in 3G (UTMS )
and 4G ( Lte band # )
to be compatible with those careers,
how to know if a phone is compatible or not without checking its Imei with the career?
Photo of Violete
Violete
  • 156 Points 100 badge 2x thumb
  • confused
Posted 3 years ago
Photo of Ahmad
Ahmad
For 3G, its 850/1900 MHz (search both at the same time)
For 4G, its 1700/2100 MHz (serch both)
If you want 3G or 4G to work, you the phone must have both of the bands within that category
Photo of Violete
Violete
many thanks Ahmad
Photo of Violete
Violete
for 4G ,there are 2 options:
LTE band 4 (1700/2100)
LTE band 10 (1700/2100)
should I select both LTE band4 & also LTE band10  ?
Photo of Spence
Spence
  • 8,354 Points 5k badge 2x thumb
No,  Koodo uses Band 4 1700/2100  only
Photo of Violete
Violete
does http://www.gsmarena.com/huawei_ascend_g7-6646.php  work with Koodo ( or wind )
Photo of Spence
Spence
Should work fine on Koodo 3G and LTE
Model G7-L03  only
Photo of Violete
Violete
Photo of Spence
Spence
Will not work on Koodo
Photo of Violete
Violete
http://help.koodomobile.com/getting-started-with-koodo/sim-cards-and-non-koodo-phones/how-do-i-know-...
Thanks but I just gave the IMEI and here is the result :
Honor Holly
Your device should work on our Network.
Your device has not been reported as lost or stolen
any Idea???
Photo of Violete
Violete
huawei honor 4x http://www.gsmarena.com/huawei_honor_4x-6754.php
 ..Hope this one  works  with Koodo/Chatr/Wind
Photo of Spence
Spence
Will NOT work on Koodo
Photo of Violete
Violete
is  this website information reliable to know if a phone works with a carrier?
http://willmyphonework.net/
