Help! Cant get data/internet to work on LG V20 unlocked. Urgent!
  • Updated 5 months ago
Data wont work on my lg V 20, it is unlocked. Tried adding APN and it just wont work, no H or LTE will come up on bars. Can send text and make calls. Help very appreciated!
Photo of Hugh Macague
Hugh Macague
Posted 1 year ago
Photo of Robert
Robert, Mobile Master
  • 107,120 Points 100k badge 2x thumb
Hello Hugh,
What's the version of the V20 you have?
Here's a list : https://www.techwalls.com/lg-v20-model-numbers-differences/
Data on?
No data block listed on your plan add ons in self serve?
Can you post screen shots of your APN settings?
Hugh Macague
From checking it is a V20 H990DS. Im from Australia and currently working near Lethbridge, got the plan today. its an $80 plan with 3gb, no data block I can see.
Photo of Jocelyn Guzman
Jocelyn Guzman
Omg it worked !!!thank you soo much for yals guyes help .!!!yal rock
Jocelyn Guzman
One last question if i switch to at&t do i have to change the apn
Photo of Allan
Allan, Mobile Master
  • 55,974 Points 50k badge 2x thumb
Usually when you put in a different SIM card it will automatically set the apn for you but if it doesn't then yes, you will.
Jocelyn Guzman
Okay thank yu
Enjoy your trip, glad we could help.
