I am unable to send photo pictures on my cell phone
Photo of Joanne Rowe
Joanne Rowe
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 192,584 Points 100k badge 2x thumb
To send picture text also known as mms make sure you have data on when sending or receiving them.
Data needs to be enabled to send or receive them but you will not be charged for the data it takes to do so. You will be charged for any data used by other apps that may use data that are open or logged into at the time of turning on your data connection if not also connected to wifi, so just make sure to sign out and or close apps like Facebook ect prior to turning it on if worried about using data if you don't have data included in your plan.
If you have a data block on your account you can not send picture messages, you will need to have the data block removed to be able to.
