Help!
Getting an "unregistered Sim" message on my Samsung Galaxy Ace. Have never had this issue until now. What is the cause and how do I fix it? Thanks.
Photo of timothyjmayer
timothyjmayer
  • 80 Points 75 badge 2x thumb
Photo of Jonathan I
Jonathan I, Mobile Master
It's a very common issue... a quick fix is usually to take out the battery and SIM card for about a minute, put everything back together, and reboot the phone.
If you're still having issues, just ensure your bills are up to date and you haven't hit your spending cap (if applicable).
If you don't get a remedy after a reboot, call customer service from any phone at 1-866-995-6636 and see what's up. Good luck!
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,506 Points 100k badge 2x thumb
Also, go to settings->wireless and networks->mobile networks and mamake sure that use only 2g networks is NOT checked.
Photo of Jonathan I
I always forget about that...
timothyjmayer
Thanks for your help appreciate it. All good now!
