Heads up display
Develop a heads uo display on a set of glasses so that you can watch where you are going and txt at the same time.
Photo of Dal Legault
Dal Legault
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
Koodo doesnt make devices they just provide service for said devices.
Check out for apps from your Operating System's app store and there is a few apps that will help you with your issue. The app makes the background of your screen see what the camera issseeing in front of you so you can use your phone and see in front of you at the same time.
Also check out Google's Google Glass which does exactly what you want.
