Headphone Jack Problem. Warranty?
I listen using headphones a lot . Yesterday, I couldn't keep my headphone to stay in the headphone jack. It keeps on popping a few millimetre up. There is no "snap" sound when you fully inserted it , and it happends to other headphones too. There is no lint/dust inside. Plese help..
I got this phone few months ago, will I be able to get a replacement model?
Photo of Jacky Lim
Jacky Lim
  • 190 Points 100 badge 2x thumb
Photo of Daniel Gunn
Daniel Gunn
  • 19,800 Points 10k badge 2x thumb
Hi Jacky,
It sounds like you may be having some hardware issues, if you have tested different kinds of headphones and it does the same thing you can bring it to the nearest Koodo kiosk and have them check the phone over and they can let you know further if it should be sent away for repair.
Hope that helps answer your question :)
  • 203,644 Points 100k badge 2x thumb
In a nutshell, maybe.
Contact koodo by phone to arrange for warranty service but keep in mind most of these warranties dont cover things like broken ports as the manufacturer considers them physical damage. Still it can't hurt to try. If it does turn out that you're not covered, you can always consider a pair of bluetooth headphones if your device supports it.
