Have: Canada wide plan on BB curve. Need: To add on a prepaid talk booster. Possible or not?
Photo of Deebs Steww
Deebs Steww
  • 92 Points 75 badge 2x thumb
Posted 3 years ago
Photo of HippieLongstocking
HippieLongstocking
  • 24,720 Points 20k badge 2x thumb
Hey Deebs?
are you a monthly customer or prepaid?
Deebs Steww
Monthly, with Canada-wide plan.
Thanks for answering!
<3Deebs.
HippieLongstocking
ok so because you are on a monthly plan you are not able to add on prepaid booster as they are two completely different systems.
If your out of airtime you can add on unlimited anytime minutes for $20 every month and then cancel when you feel that you don't need the add on anymore, or just change your plan to a unlimited Canada wide plan
Deebs Steww
That`s what I`d suspected.
So the $20 unlimited anytime minutes would be pro-rated, right?
If I only use it for 1.5 billing cycles before I remove the add-on, it would only charge approx: $30 between the two months.
Thanks hippie
HippieLongstocking
exactly!
