Group Texting Help....
I have a Moto G phone. How do I send a group text and save the group? I created a group but I can't figure out how to text to this group. If I add more than 1 phone number to a text, the message keeps saying sending....forever, and it doesn't go to anyone.
Photo of Paula Devereaux
Paula Devereaux
  • 160 Points 100 badge 2x thumb
Photo of John Burke
John Burke, Mobile Master
Which phone are you using?
If using an Android, I use an App called Sliding Messaging to have group chats. However, I need to add the people in individually, not as a group.
Photo of Billy
Billy
  • 584 Points 500 badge 2x thumb
Go to your text messaging screen
compose a text message
top line where you type in name and numbers
type the first name in. ones complete select on that field again and type another name in
then type your message
it does take longer then usual to show sent but that's all it is
one thing to keep in mind for group text, when they reply it will go to their individual thread not in the group thread.
you might be better off with whatsapp, facebook messenger or BBM
Paula Devereaux
It's a Moto G. I coach a soccer team and text 26 players. My old phone was great. I can't even forward the text to another player, I have to re-type 26 times and it's annoying me to no end. My old phone (slider) was great - thus the reason I didn't want to change....lol
Paula Devereaux
I tried but it keeps saying "sending" and the recipients never receive the text. I'll try again. Maybe I'm not waiting long enough for it to go through.
Photo of Robert
Robert, Mobile Master
  • 106,744 Points 100k badge 2x thumb
You can use the copy and paste function so you don't have to re-type the same text over and over again. And yeah, wait a little. Try sending a text to 2 people you know and see if it works. 26 texts may take a while to send...
Photo of Dennis
Dennis, Mobile Master
  • 195,890 Points 100k badge 2x thumb
I bet it's trying to send the group text as a picture message.
Try turning on your data and it will send. No Wifi is not the same thing. However, if you turn on data while on wifi there should be no unexpected Data charges and it will allow the text to send. Just remember to turn off data when you are done sending
Paula Devereaux
Thanks Dennis.....it worked. I must remember to turn on data when sending :-)
Photo of Dennis
  • 195,746 Points 100k badge 2x thumb
You're welcome. When the Moto G sends a group text it treats it like a picture message, which is why data needs to be enabled
