Greatest phone plan!!
  • 2
  • Idea
  • Not Planned
40 $ a month will get you lets say 1000 koodo points+ each month you don't use all your points they add up
internet= 10 koodo points will get you 10 mb
phone call= 1 koodo points will get 1 min
texting= basicly the same
so let's say one month you do more calling while you have more time for talking
and the next month you could use data more then calling
Photo of Normand Brunet
Normand Brunet
  • 90 Points 75 badge 2x thumb
  • 2
Photo of Ivan
Ivan, Mobile Master
This isn't really an idea for a phone plan, but rather for some kind of customer rewards plan. You should consider changing the title to avoid confusion.
Photo of KaneSlavik
KaneSlavik
  • 6,464 Points 5k badge 2x thumb
And the current system doesn't allow for this type of reward structure. There would need to be changes done on the back end to allow this.
Normand Brunet
I might not of explain myself wright but you can turn your koodo points towards anything u like (calling,texting,data or watever else)
Photo of KaneSlavik
KaneSlavik
I understand what you were explaining. It's just not possible right now and it would be quite the investment for Koodo to add to their systems. Plus it would make the billing a lot more complicated.
Photo of Sophia
Sophia, Mobile Master
What you're describing here, Normand, is almost exactly like Prepaid already works :)
- $15 gets you unlimited texting (that bit is different from your proposal)
- $25 gets you 500 "koodo points" and what you don't use is kept each month
- Canada phone call = 1 "koodo point", US phone call = 2 "koodo points" and the rest of the world 5 "koodo points"
- $30 gets you 1000 internet points
- 10 internet "koodo points" will get you 10 mb
The months you use more time for talking you use more talk koodo points, and the months you use more for data you use more internet koodo points :)
Sounds like you found the perfect solution to your very well thought out idea :D
