Going to Mexico and resort has free Wifi - do I need to buy an add on?
  • Updated 2 years ago
I am confused with everything that I have read. I am going to Mexico for one week. The resort has free Wifi. Will I need to add roaming or anything else or am I covered because Wifi is free? Help!
Photo of Lola McMurter
Lola McMurter
Posted 2 years ago
Photo of Tiz
Tiz
  • 4,604 Points 4k badge 2x thumb
With WiFi you will have data and phone (if you do not have it on your cell/laptop, download Skype, Whatsup, Messenger, etc). You are set up.
Photo of Jonathan I
Jonathan I, Mobile Master
WiFi is for internet, not cell network usage, so if you still want to use any minutes, texting, or data in your plan while in Mexico, you'll have to add a roaming package or try the pay-per-use rates, which can be very expensive. However, there are a lot of ways around using the cell networks and just using WiFi while on your trip to communicate. Skype, Viber, Facebook, WhatsApp, BBM, etc.
You can also unlock your phone (if it isn't already) and use a local provider's SIM while you're down there.
Photo of BobTheElectrician
BobTheElectrician
  • 67,712 Points 50k badge 2x thumb
Best to consider it a holiday from everything, including cell interruptions. Roaming outside of well defined urban areas can be iffy, to say the lea$t, and your free wifi at the resort may end up being one computer terminal being shared by a multitude of guests.
Photo of Teresa Chiu
Teresa Chiu
  • 80 Points 75 badge 2x thumb
can somebody help me stop following any conversation. I been receiveing over more than 40 conservation in a day. This is crazy. I donot want to be in this Koodo Community Forum. thany you.
Photo of Tayeb A
Tayeb A, Employee
  • 18,208 Points 10k badge 2x thumb
Hey Teresa,
You can unsubscribe from Community notifications by clicking on this link: http://koo.do/1QYaSeW
Uncheck all check checkboxes then click on "Save Emails & Notifications"
Hope this helps!
Photo of Daniel
Daniel, Employee
  • 5,714 Points 5k badge 2x thumb
Hi Lola!
If you only want to use Wi-fi while in Mexico and do not want to use any roaming services (voice, data and/or text), I suggest that you put your device on Airplane Mode. Your Wi-fi will still work and you'll be worry free :)
Have a great trip!
