Going to Ireland next week. Will purchase add-on for ld, data& text. Will I be charged roaming fees also. If so, how does that work?
  • Updated 9 months ago
Travelling to Ireland next week. Going to purchase travelling add-on for ld, data& text. Will I be charged roaming fees as well? If so, how does that work?
Photo of Brian
Brian
Posted 9 months ago
Photo of Goran
Goran, Mobile Master
  • 90,544 Points 50k badge 2x thumb
No you're purchasing an add-on and the only one with data and minutes available is 40 dollars that includes 50 minutes/MB data / SMS. You get unlimited SMS incoming with or without. If you need more than the bare minimum, and 50MB is effectively nothing, I suggest getting a local prepaid Sim. Here is the link for options:
http://prepaid-data-sim-card.wikia.co...
If you need a Canadian number then you can use VoIP services such as Fongo and you're covered there.
If you must use your own number be sure to also add international voice and data roaming within your add-ons section in self-serve. They are zero cost and will enable the features.
