GOING TO CUBA IN SEPTEMBER /WHAT WILL IT COST TO TEXT TO CANADA FROM CUBA AND HOW DO I PAY FOR IT
  • Updated 2 years ago
SAMSUNG S6 EDGE I HAVE A MONTHLY PLAN FOR MYSELF AND MY WIFE
Photo of Alexander Mirc
Alexander Mirc
Posted 2 years ago
Photo of BobTheElectrician
BobTheElectrician
  • 67,712 Points 50k badge 2x thumb
Start here:
http://help.koodomobile.com/coverage-long-distance-and-travelling/travelling
You can choose from a few add-ons or do pay-as-you-go.
Please read and follow the instructions carefully: you have to activate roaming in your account since overseas connections are by default blocked to avoid expensive $urprise$. If you are ordering by texting, do that while you are still in Canada and on the day that you are leaving.
Photo of Goran
Goran, Mobile Master
  • 97,818 Points 50k badge 2x thumb
The cost will be included in your bill. It could be delayed depending on the carrier roaming partner reporting what was used but it shouldn't be. You also have the option to rent a Cubacel Sim card at any ETECSA office, which is also found at major airports in Cuba.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,766 Points 100k badge 2x thumb
Note that if you do obtain a local sim card you phone will need to be unlocked first.
