Going to cuba
  • Updated 5 months ago
I would like to be able to just send text while being in cuba is there a plan just for text like i had took a few years ago?
Photo of Katia Allain
Katia Allain
Posted 6 months ago
Photo of Goran
Goran, Mobile Master
  • 97,688 Points 50k badge 2x thumb
No. There is easy Roam and there is pay per use texting rates and that's all.
Katia Allain
Oh and how much does the texting rate work?
Photo of Allan
Allan, Mobile Master
  • 61,680 Points 50k badge 2x thumb
You need to make sure the $10 International Easy Roam add-on isn't on your account.
Photo of Robert
Robert, Mobile Master
  • 106,468 Points 100k badge 2x thumb
For that you would need to access your add-ons to see if it's on your account or not.
Katia Allain
It was on it so i remouve it?so should it be good now for 60€ per text or?
Photo of Goran
  • 96,388 Points 50k badge 2x thumb
Yes you remove it and then you're good for 60 cents per outgoing text.
Katia Allain
Ok perfect thanks
