going to Australia. With intl roaming will I be able to call US at a reduced call charge as I have $3.oo ld saver
  • Updated 10 months ago
I will be going to Australia. With international roaming will I be able to call US at a reduced call charge as I have international $3.oo on my existing plan
Photo of Don Mellor
Don Mellor
Posted 10 months ago
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,636 Points 100k badge 2x thumb
If you add a roaming package, using your phone in Australia will use the minutes from the roaming package. If you don't add a roaming package, you will be charged $1.50/minute. This is what it costs to use your phone on a network which is not owned by koodo, and will be the same regardless of which country you are calling.
Photo of Robert
Robert, Mobile Master
  • 107,362 Points 100k badge 2x thumb
Roaming and the international save add-on aren't the same things. The international saver gives you better rates from Canada to the US but if you need to call from outside canada you need "roaming" packages that can be found here : https://www.koodomobile.com/help/travelling-outside-us
