Ghost calls to voicemail?
My booster usage history online shows a number of short calls to the voicemail number, the most recent of which occurred while my phone was in my locked locker at the gym. My call history on my phone doesn't show any calls during this time. What's going on? Is there an app or something that could be doing this?
Photo of KB
KB
Photo of Du
Du
  • 3,762 Points 3k badge 2x thumb
You might want to scan your phone, sounds like Spyware app at work
Photo of Matthew Sider
Matthew Sider
  • 2,432 Points 2k badge 2x thumb
I agree may be Spyware please download cm scurity
clean master may be the problem best do software reset may help I hope this helps you
Photo of Theresa M Ferbie
Theresa M Ferbie
  • 210 Points 100 badge 2x thumb
It's not Spyware malware or any other security breach. I have 2 phones on a plan with koodo and it happens on both . Also both have security
Photo of Ray
Ray
  • 7,754 Points 5k badge 2x thumb
That's just the way voicemail works. When someone calls and you don't answer, it shows up in your history as an outgoing call to the voicemail number, even if they didn't leave a message. It should not deduct any time from your boosters - if you notice that this is happening you should call customer service to get it fixed.
