getting double minutes without changing current plan
hi, I m using canada wide talk and text 35 plan for 5 months. i get 200 minutes in this plan. but I want to ask that cant I get 400 minutes according to your recent update of this plan
Photo of mani singh
mani singh
  • 262 Points 250 badge 2x thumb
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,496 Points 100k badge 2x thumb
You have to change to the new version to get the double minutes.
Photo of mani singh
mani singh
sry , I didnt understand. Wht do u mean by new version?
Photo of Sophia
Sophia, Mobile Master
  • 142,934 Points 100k badge 2x thumb
You need to go in self-service, mani, and upgrade your plan manually. You won't automatically get the double minutes, you will need to change your plan (to the plan with the same price, but double everything)... it's free and then you can enjoy the double minutes and data forever :D
Photo of Erwin
Erwin
  • 23,576 Points 20k badge 2x thumb
Hi Mani,
Plan updates does not automatically change your plan, you will still have to change plan by going to your self serve. Hope this simplifies it :)
