galaxy s4 LTE
  • Updated 2 years ago
I have a galaxy s4 and everything works very well only I have problem with the 4G or LTE it doesn't work...my phone it's GT-I9505
Network:
2.5G (GSM/ GPRS/ EDGE): 850 / 900 / 1800 / 1900 MHz
3G (HSPA+ 42Mbps): 850 / 900 / 1900 / 2100 MHz
4G (LTE Cat 3 100/50Mbps): 800 / 850 / 900 / 1800 / 2100 / 2600 up to 6 different band sets.
Photo of mohideen
mohideen
  • 240 Points 100 badge 2x thumb
Photo of PZABOY
PZABOY
  • 5,142 Points 5k badge 2x thumb
If the phone is brought from another carrier you need to double check its compatibility with koodos network.
Use this tool:
http://koodomobile.com/en/on/switch2k...
Photo of mohideen
mohideen
I did and the says my phone will not work with Koodo but how it can be like this when I'm using my phone now with koodo and everything works very well only the 4G doesn't work!!! anyways thank you
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,938 Points 100k badge 2x thumb
Are you in an area that's covered by LTE?
Photo of mohideen
mohideen
yeah it's and the postal code is M4Y 2X6
Have you ever had any phone with koodo get LTE in your area?
Photo of mohideen
mohideen
No, this is the first one
Photo of MatB
MatB
  • 32,478 Points 20k badge 2x thumb
Postal code you provided is well covered with LTA coverage your phone seems to be compatible with kOODO HSPA (HSPA/LTE 850/1900 MHZ frequency)
Photo of mohideen
mohideen
Thx
Photo of Yannick
Yannick
Hi Mohideen, you need a specific SIM card to enjoy LTE on your phone. The V3 SIM card is solid purple and white in color. If you already have one, I suggest that you give our technical support a call. We have limited support on non-Koodo phones but we'll do our best :)
________________________
Photo of mohideen
mohideen
Thank you and I will call soon
Photo of mohideen
mohideen
I went today to Koodo the one in Eaton Center and the man who's working there he told me there are no SIM card like this kind what you wrote and they have only the same kind like what I have already the one with white and orange color!!! Can you tell me from where I can get that one? Toronto
Photo of mohideen
mohideen
hello!!!
Photo of Jorden
Jorden, Mobile Master
  • 33,404 Points 20k badge 2x thumb
According to Wikipedia, telus uses band 4/1700 MHz for LTE which would explain why you are not getting it.
http://en.wikipedia.org/wiki/List_of_...
Where is the phone from?
Photo of Jorden
As a matter of fact I see it's different from the version for AT&T in the states meaning that for sure it's LTE bands are different from what all the major Canadian carriers use.
Photo of mohideen
mohideen
Yeah maybe..Thank you
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,808 Points 50k badge 2x thumb
There is also that rare chance that it being a non-Koodo phone, data may not work. It should, but there is no guarantee.
Photo of Fernando Jauretche
Fernando Jauretche
  • 60 Points
S4 only supports 1 out of 3 of T-Mobile's LTE bands. If that's not what is deployed near you, then search it here,  http://ellexroot.com/
