galaxy s4 wifi connection issues
  • Updated 2 years ago
I have a galaxy s4. It have a wifi connection problem. Wifi connection is good but doesn't working internet connection. At the same place I used another device(LG G4)is working good both of wifi connection and internet connection. I don't know why just galaxy s4 is disconnect to internet.
Photo of Ryan Kim
Ryan Kim
  • 72 Points
Posted 2 years ago
Photo of Gabriel Bergeron
Gabriel Bergeron
  • 192 Points 100 badge 2x thumb
If I understand correctly what you are saying is that you are connected to the wifi network but you are not getting Internet from that connection.
-You can try to turn off and on the wifi on the device.
-Reboot your phone
-Reboot your router.
-Check your router setting to see if you have a mac address whitelist or some sort and check that the dhcp is working well on the router.
Hope this helps.
Photo of Tiz
  • 4,604 Points 4k badge 2x thumb
It seems to be a problem with the Galaxy since the LG is working fine. What kind of browser are you using? I would try to uninstall the browser and reinstall it. Also try to install a different browser.
