Galaxy S4 suddenly not connecting to data anymore
All of a sudden my data won't connect anymore. I can make and receive calls and texts and connect to wifi, but the data icon doesn't show up and it won't connect. I've checked the settings and it's set for data. I've restarted it, taken out the battery and sim, and it still doesn't work. I've tried going on and off flight mode, I've checked the mobile network. Help!
Photo of Lindsey Ryzak
Lindsey Ryzak
  • 90 Points 75 badge 2x thumb
Posted 3 years ago
Check your Apn (access point names) and make sure Koodo.sp is There and selected
Settings....
More Networks...
Access point names...
If it's not there you may have to add it.
See here for more information
http://koo.do/unlockedphone
Lindsey Ryzak
yes it's there and checked. Network mode is also lte/wcdma/gsm
Go online to your self serve account and see if a data block has been added to your account.
If not, you may just need a new sim.
One more item
Goto...
Settings
More Networks
Mobile network
Network selection
Allow it to scan and then choose automatic selection
Lindsey Ryzak
Yeah I tried the network selection already too.And it doesn't look like there is any kind of block. I guess I'm heading to the store to try a new sim.
Another try...
Settings
Data usage
Make sure set data limit is unchecked
Another try...
Settings
Data usage
