Galaxy Alpha...If I buy a samsung galaxy alpha with another company, since Koodo does not sell it yet. Will it work with Koodo? Thanks
Im currently with Koodo and have a Samsung Galaxy S4...I want to get the new Galaxy Alpha but Koodo does not currently carry or sell it. My cell is broke, so I need a new cell sooner then later. I dont want an Iphone or other phone. Im stuck on the Galaxy Alpha. Will it work if I buy it else where and bring it to Koodo?
Photo of Chris
Chris
Photo of Daniel Gunn
Daniel Gunn
  • 19,800 Points 10k badge 2x thumb
Hi Chris,
If you bring the Samsung Galaxy Alpha to Koodo it has to be unlocked and it also has to support HSPA 850/1900 in order to work on Koodo.
Hope that helps answer your question :)
Photo of Chris
Chris
I appreciate the answer but I have no idea what that means lol. Maybe you could explain a little easier for me. Thanks.
Daniel Gunn
That's okay, all it means is that in order for the phone to work on Koodo it has to support those frequencies that Koodo uses. If the phone doesn't support them then the phone won't work.
I checked the specifications of the phone and it looks like it should work (granted the phone is unlocked).
Information is here:
http://m.gsmarena.com/samsung_galaxy_...
Photo of Chris
Chris
How do I go about unlocking it? or buying one unlocked? I have tried looking online but it hasnt really told me much.
Daniel Gunn
Hi Chris,
If you bought the phone with a different provider you can get it unlocked online at cellunlocker.net or GSM liberty for a fairly cheap price. If you were buying it unlocked you can always check out eBay, Kijiji, or even Negri Electronics, Amazon is good too.
Hope that helps :)
Photo of Robert
Robert, Mobile Master
  • 103,858 Points 100k badge 2x thumb
Maybe an Alpha from Telus will work too!
Photo of Chris
Chris
They dont sell them either..yet anyways. It would be nice to even have a date is Koodo will carry it
Photo of Robert
You're best guess would be to follow their Facebook page. There will be where they will be making all the announcements for new phones and such. Or they do make him on the community as well
Chris, you need to investigate the exact model you'll be purchasing irregardless of what phone it is, it needa to carry service on at least the 850/1900 mhz hsdpa (3g) bands. Don't be confused with the 2g bands which may have the same number but aren't the same.
You shoukd ask the supplier for the exact model number. Check on GSM Arena for the specs on your exact model.
For instance....
Daniel Gunn
What phone are you using Chad? One M8?
I picked up the Alcatel Idol x+
You?
Daniel Gunn
Still rocking the Nexus 4 :) is that phone you have any good you find?
Yeah, im enjoying it much.
Photo of Jillybean74
Jillybean74
  • 60 Points
I am looking at the same phone and hoping it will work with Kodoo. It looks like the model I want to buy will support the 3G frequencies, but what LTE frequencies does Kodoo use? The model I will likely buy supports LTE 700/2100/1800/2600/850/900/1900
Photo of Jonathan I
Jonathan I, Mobile Master
Those are fine. You'll be good.
Missing the 1700mhz band in LTE however.
Photo of BobTheElectrician
BobTheElectrician
  • 62,114 Points 50k badge 2x thumb
AT&T model should work well with Koodo. US suppliers (Amazon & eBay) don't know anything much about Canadian carriers. I've used Koodo-sourced Samsung phone on AT&T and it worked flawlessly. Phone must be unlocked.
