Galaxy 5 neo won't switch on. Battery is fully charged. It was working fine.
  • Updated 1 year ago
Good day one and all.
My phone was working fine this am and now [830pm] it won't switch on from sleep mode. The battery is at 95%. The fixes I have tried are 1) holding power/volume down/home key down for 45 secs; 2) taking the battery out, replacing it and trying (1) again; 3) holding the power key down and plugging into my desktop with USB cord. Nada. Zilch. Any ideas how to get this functioning again or why this even happened.
Photo of Robert Yule
Robert Yule
  • 430 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Cory
Cory
  • 10,482 Points 10k badge 2x thumb
Sounds like a hardware fault. Is it still under warranty?
Photo of Allan
Allan, Mobile Master
  • 57,106 Points 50k badge 2x thumb
Try taking the battery out, hold the power button for one minute, put the battery back in, and then try turning it on.
Robert Yule
Hi Cory. Sorry for the delay in replying. I had the same thought re hardware issue. I purchased the phone outright from a Telus store 11 months ago but I am not sure about the warranty.
Photo of Andy Girard
Andy Girard
  • 222 Points 100 badge 2x thumb
Use the reset button and it should work.if not take it to a repair shop.
Robert Yule
Hi Allan   tried that and no go
Andy Girard
Hi. Robert. ,andy girard try mine and see if that works for u
Robert Yule
Thank you Andy tried that as well. Thanks for your help but it looks like I'm headed for the repair shop
Photo of Cory
Cory
It will have a 1 year warranty, so I would take it in and get it checked/repaired while you still can. :)
Photo of rikkster
rikkster, Mobile Master
Can you get into recovery mode?
  1. Press and hold Volume UP key + Home Key
  2. then Press and hold Power key
  3. Release all key when Samsung logo appear then you will see Android System Recovery
  4. Use Volume UP key and Volume Down key to select Menu
  5. Use Power key to Confirm or Execute Menu
Once you're in this menu, you have three options. You can try to reboot the phone from this menu; wipe the cache partition or perform a factory reset, (wipe data /factory reset). If the problem persists, it's likely a hardware issue.
