frustrating busy signal despite an open line
Just came back from Spain where I used another SIM card for 3 weeks.
Have replaced my original Koodo SIM card.
Tried to phone my cell, which was not being used, from my land line and repeatedly received a busy signal.
What can I do?
Photo of Barry Breger
Barry Breger
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of BobTheElectrician
BobTheElectrician
  • 62,114 Points 50k badge 2x thumb
May have to reset APN and network values.
0. Settings=>More networks=>Mobile networks=>Network operators (it may take some time to scan all available networks)=>Choose “Select automatically” or Koodo.
Then re-start the phone*.
1. Settings=>More networks=>Mobile networks=> make sure Mobile data is checked.
2. In the same window, Network mode => LTE/WCDMA/GSM should be selected. You can toggle between the first 2 values and re-start your phone. Sometimes this will fix your problem.
3. double check APN settings:
http://aide.koodomobile.com/Portals/0...
*Re-start the phone = preferably removing the battery for a few minutes.
If you see a reply that's helpful, please give it a star.
Photo of Dennis
Dennis, Mobile Master
  • 187,648 Points 100k badge 2x thumb
When you left for Spain what did you do with your account/plan?
Why did you get a new sim? Did you activate/update your new sim on self serve?
BobTheElectrician
If we presume that the "new" SIM was a local Spanish one, then it all seems to fall into place. The APN and network settings on the phone would have been changed. Koodo SIM re-inserted would have been confused at least.
Original poster should clarify.
Photo of Dennis
APN should have no affect on calls. APN only controls Data and MMS since it uses the Data pipeline
BobTheElectrician
APN = data only. But Network mode may make a difference: Europe uses different frequencies for voice. Phone may be stuck on those till it gets a good awakening...(2)
Photo of Dennis
Except it's an iphone
BobTheElectrician
iDidn't see that in the original post. Would be nice if someone more experienced on that platform could help this guy out.
Photo of rikkster
rikkster, Mobile Master
If everything is okay with your Koodo account, you could try resetting the network settings as a last resort, though there are a few basic steps to try first.
1). Apple suggests removing the SIM Card and reinserting it. Allow the iPhone to acquire the network again.
2). Toggle Airplane mode: tap Settings, turn Airplane mode on, wait three seconds, and then turn off again. Restart your iPhone.
3). With SIM card installed in phone; go to: Settings > General > Reset > Reset Network Settings (iPhone 5, iOS 8.0.2) - this step will reboot the iPhone and restore the default network settings. Note: Resetting network settings on your device will erase all current saved settings, including Wi-Fi passwords, preferred networks, and VPN settings.
Barry Breger
thank you all.
I restarted the phone after verifying the networks - didn't do anything complicated and, surprise, the phone works again.
cheers
