From Canada traveling to UK. How to activate and will I be charged for incoming calls and texts
  • Updated 6 months ago
Hi. I am traveling to the UK. I don't want to sign up for easy roam. Will use pay as you go. Do I have to activate. Anything and will I be charged for incoming text messages and calls?
Photo of sroutledge .
sroutledge .
  • 112 Points 100 badge 2x thumb
Posted 6 months ago
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,052 Points 100k badge 2x thumb
Incoming text messages are free. Incoming calls are not, but you would only be charged if you answer them. In order to connect to the network overseas, you will need to add the free "international voice roaming" add on via self serve.
Photo of Dennis
Dennis, Mobile Master
  • 187,544 Points 100k badge 2x thumb
There is nothing to activate. Just make. Sure Easy roam is not one of your add-ons on your self serve
