forgot 4 digit passcode for Samsung...
  • Updated 8 months ago
How do I find out password for my Samsung....
Photo of Robyn King Gaudet
Robyn King Gaudet
Posted 8 months ago
Photo of Goran
Goran, Mobile Master
  • 97,204 Points 50k badge 2x thumb
Which Samsung device? If you have Samsung device software set up then you can unlock it from a computer by logging into your Samsung account. If it's not set up, you might be able to enter the password wrong 5 times to have the option to unlock with your google account password. If you cannot do that then I'm afraid you'll be forced to factory reset your phone. You can use ADB if you have USB debugging enabled via computer connection.
Photo of Allan
Allan, Mobile Master
  • 62,352 Points 50k badge 2x thumb
Once entered incorrectly enough times you should be prompted to login to your Google account to unlock your phone.
You also should be able to login to Samsung's find my phone and unlock it there if it is set up.
