forget pasword plz help
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: *611 or 1-866-995-6636 mentions
forget password
Photo of Ghazala Shaikh
Ghazala Shaikh
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,808 Points 50k badge 2x thumb
This is the praise section. You would need to put this in the questions category.
What password are you referring to?
Photo of Yannick
Yannick
Don't forget to check the tags, Tyler :)
Zaphod Beeblebrox
I guess I should start using them hahaha. I'm just so used to not seeing any tags
Photo of Yannick
Yannick
Hi Ghazala, you can retrieve your Self Serve password by using our recovery tool: http://koo.do/nlEHtH. If you're still experiencing issues, give us a call at *611 from your cell and we'll assist you. Thank you!
________________________
