foreign phones?
If I want to buy a lenovo phone, that is only sold in china, can I bring it to Koodo and be placed on a 30$ talk and text plan, as long as it supports the same frequencies? I think its 2100 in Candada.
Photo of Jean-Luc Bastarache
Jean-Luc Bastarache
Photo of Sophia
Sophia, Mobile Master
  • 143,114 Points 100k badge 2x thumb
If the frequencies fit, you should be able to use it... though in truth, many Chinese phones only have the GSM frequencies and won't work with Koodo at all (they'll work with Rogers in a crippled way). You can try... but Koodo can't guarantee it will work :)
Photo of HippieLongstocking
HippieLongstocking
  • 24,720 Points 20k badge 2x thumb
Hey Jean!
from previous experiences, most phones from forgein countries dont work with our network. if you can get the serial number before you purchase the phone you can check the phone compatiablity tool http://koodomobile.com/en/on/phonecom...
Photo of Dennis
Dennis, Mobile Master
  • 196,890 Points 100k badge 2x thumb
You also have to make sure it is not locked to a specific carrier in addition to making sure the frequencies are right.
Koodo has no restrictions on using phones not sold by them or from another comapny/country
Jean-Luc Bastarache
Wow that was fast, thanks guys, thins helped a lot!
