For those with laggy Android phones (Galaxy Ace, One V, and others)
  • 10
  • Idea
  • Planned
I've noticed a lot of complaints about lower-end Android devices and a noticeable decline in performance and usability. The community has been quite helpful in guiding users through various steps to remedy these problems, but many casual users will be frustrated by doing this "maintenance" work on a regular basis.
I use an app for my Android devices that makes device cleaning a breeze. It's called Clean Master and can be found here:
https://play.google.com/store/apps/de...
Disclaimer: I do not work for, nor am I affiliated with Ksmobile (app developer). My suggestion is based on my own satisfaction with the app and I believe that it could help a lot of users.
Perhaps Koodo could place something like this in the FAQ section.
Photo of Ivan
Ivan, Mobile Master
  • 10
Photo of rikkster
rikkster, Mobile Master
  • 68,282 Points 50k badge 2x thumb
It works, I have Clean Master installed on a couple of older devices.
Android Assistant isn't bad either.
https://play.google.com/store/apps/de.....
Photo of stillgolfing
stillgolfing
  • 1,464 Points 1k badge 2x thumb
Please define "Laggy"?
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,220 Points 100k badge 2x thumb
Laggy is when things seem to hesitate or "lag" when scrolling through screens or opening apps/games.
I've tried clean master and it works good. I use cache cleaner pro and memory booster pro & set them up to work automatically at a user specified time period or threshold so you can set it and forget it and just have your lag disappear the possible amount it can.
Here's the download links to the apps I mentioned above.
Cache cleaner Pro - https://play.google.com/store/apps/de...
Memory Booster Pro - https://play.google.com/store/apps/de...
*there's a free version of both apps as well*
Photo of John Lee
John Lee
If I could thumb up your comment Paul; I totally would.
Photo of Sumaya K.
Sumaya K.
  • 7,350 Points 5k badge 2x thumb
Thanks Philosoraptor, I think it'll be a great Facebook and blog post.
Photo of Maxime Paquet
Maxime Paquet
  • 666 Points 500 badge 2x thumb
thanks for this apps
