For some reason my phone won't turn on , it's on charge but nothing is happening.
  • Updated 1 year ago
Photo of amber
amber
Posted 1 year ago
Photo of Mathieu
Mathieu, Mobile Master
  • 60,828 Points 50k badge 2x thumb
Hi Amber,
Photo of Allan
Allan, Mobile Master
  • 56,506 Points 50k badge 2x thumb
Try using a different charger, different wall outlet/usb port, etc.
Have you tried holding down the power button and see if it turns on? Is the screen black and nothing else appears?
Photo of Ivan
Ivan, Mobile Master
If the battery completely discharged, it may take up to half an hour of charging before the phone will even turn on.
Photo of titaniumtux
titaniumtux
  • 12,912 Points 10k badge 2x thumb
Depending on the phone model (and I know ziltch about iPhones), hold power and either volume up or volume down for 15 seconds (whether it's volume up or volume down will vary per handset).
