FM radio
  • Updated 12 months ago
I just bought a samsung galaxy core lte because I was told this is suppose to still have no data FM radio and there is no FM icon on this phone. What gives?
Photo of Franco Buratti
Franco Buratti
Posted 3 years ago
Photo of Robert
Robert, Mobile Master
  • 103,372 Points 100k badge 2x thumb
Maybe you need to download an app for that?
https://www.youtube.com/watch?v=tbAT3...
Photo of BobTheElectrician
BobTheElectrician
  • 61,576 Points 50k badge 2x thumb
Check out gsmarena:
http://www.gsmarena.com/results.php3?...
SOME Core models DO have the radio, some DON'T.
An LTE phone will be geared towards data.
Most likely on your model:
http://www.gsmarena.com/samsung_galax...
Photo of rikkster
rikkster, Mobile Master
  • 66,988 Points 50k badge 2x thumb
It would be helpful if Koodo could include model numbers next to the devices they carry to eliminate this sort of confusion. On-board memory/storage size would also be helpful as Samsung manufactures several variants of the device in 8 and 16GB storage capacities worldwide.
The model Koodo carries is the 16GB version running KitKat. This version does not include FM radio.
Samsung Canada
http://www.samsung.com/ca/consumer/mo...
SM-G386W - User Manual - FM Radio would normally be listed under the heading Media and is not present with this model.
http://downloadcenter.samsung.com/con...
Samsung Philippines
http://www.samsung.com/ph/support/mod...
SM-G386F - User Manual - lists that the FM radio is present with this model under the heading Media.
Photo of geoffroy.men
geoffroy.men
Koodo should really make this information known to the public. I just went to a koodo store to buy a phone. The seller wasn't sure if the Core LTE had FM Radio. For me, not having FM Radio is a dealbreaker. I was in a hurry and there was no way to verify this. So I bought the Moto G even though the Core LTE seemed like a better buy for the price. I'm glad I did cause I would've been stuck with a radioless phone otherwise.
It's not a good reason to ignore this feature "because most people don't look for it". Well some of us do. It's not much work to reach out to that market.
Photo of yd
yd
  • 176 Points 100 badge 2x thumb
regard less the phone i will return the lg g4 i juste buy to night cause of that
no fm radio enable  in it
Photo of Cory
Cory
  • 10,482 Points 10k badge 2x thumb
99% of phones DO NOT have FM enabled in Canada. The LG G6 does for example, and the S8/S8+ doesn't.
I have owned the iphone 4, 4s, 5, 5s, 6, LG G2, G3, G4, Samsung S5, S6E+, S7E, ZTE Axon 7, Note 7, Moto Z, S8+, and now the G6 (just to name a few of the phones I have owned). The ONLY one that has FM that I can remember is this G6.
*Edit* Damn. I change phones far too often....
