firmware upgrade issue notes 2
Encountered a problem with firmware upgrade for my Samsung Notes 2.
Photo of Pierre M.
Pierre M.
Photo of Daniel Gunn
Daniel Gunn
  • 19,800 Points 10k badge 2x thumb
Hi Pierre,
What kind of a problem did you run into? If you can provide a few more details we may be able to find a solution for you to help get the phone updated properly.
Photo of Pierre M.
Pierre M.
Hi Daniel, I proceeded with the Firmware upgrade suggested via Kies and there was an issue during the process. Software suggested to do a Emergency Recovery and when I tried that, the software did not recognize my Galaxy Note 2 anymore. Tried the Firmware Upgrade and Initialization by providing the Model Name and S/N and get a 'This device's version cannot be updated' after starting the upgrade in ODIN MODE. So now I'm looking to upgrade the Firmware through a software called ODIN. Any other solutions ?
Daniel Gunn
Hi Pierre,
Sorry I didn't get back to you earlier, to be honest I'm not sure where to look in this case, on the other thread you posted Paul Deschamps (Mobile Master) has given you some information as to where you should look and hopefully go from there. I apologize for not being more helpful.
https://c.getsatisfaction.com/koodo/t...
Hope that helps
Photo of Pierre M.
Pierre M.
I was able to recover my device using the following instructions:
http://www.samsungupdate.com/how-to/h...
Got the firmware from Sammobile (better than Gator).
Cheers !
