Fees for incoming US calls on CanTalk300+
Which add on allows me outgoing and incoming calls to and from US if I have Can Talk 300+ mins? In the add on list, I only see reference to outgoing calls to US - nothing about what I'll be charged for incoming.
Photo of susan
susan
Posted 3 years ago
Photo of David
David, Mobile Master
  • 89,034 Points 50k badge 2x thumb
There are no additional costs to receive calls from the USA while in Canada, so the add on you have found is the one you want.
Photo of Justin Robichaud
Justin Robichaud
  • 5,002 Points 5k badge 2x thumb
Incoming calls should be free no matter where they come from.
With the Unlimited US add-on that you found you should be able to enjoy all the calling you need to and from the U.S.
Photo of BobTheElectrician
BobTheElectrician
  • 61,556 Points 50k badge 2x thumb
Point of order, yer honour! Not FREE, but just use regular minutes. My esteemed colleague one post below should be advised as well. As usual, Dr. dfbutt has the right jurisprudence and interpretation..
Photo of Robert
Robert, Mobile Master
  • 103,734 Points 100k badge 2x thumb
Incoming from US will always be free in Canada
For outgoing you would need the add-on you mentionned
BobTheElectrician
  • 61,898 Points 50k badge 2x thumb
There is never any free lunch. You have to pay up front for it. Any incoming call from Mars or the moon uses regular minutes on your plan. Apparently outgoing can also use regular plan minutes. You are just avoiding the upcharge for long distance. Your only defense 100% is to have an unlimited plan to begin with.
Don't take my word for it.
