FaceTime and iMessage not activating
iPhone 4 iMessage and FaceTime stuck on waiting for activation I've tried resetting network setting rebooting even went as far as restoring, to no avail. Help me please!!!
Photo of mike
mike
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,676 Points 100k badge 2x thumb
Try disabling both apps, restarting the phone and enabling them again.
Photo of mike
mike
Tried and still the same waiting for activation
Photo of Jonathan I
Jonathan I, Mobile Master
This may sound silly but do you have an active internet connection while doing this? FaceTime requires data, I believe, and iMessage needs internet in some capacity (WiFI or data).
Photo of mike
mike
Yes active data and wifi on at all times while attempting to activate
Photo of Dennis
Dennis, Mobile Master
  • 196,772 Points 100k badge 2x thumb
Everything seems to be running n Apple's side:
http://www.apple.com/ca/support/syste...
Did you get this to work yet?
Are you able to sign up for icloud on your phone? it should use the same apple ID you are setting for iMessage/FaceTime
Photo of mike
mike
No it's still not working for me..and yes I have an iCloud. It just sits on waiting for activation for about an hour and then fails. What could be wrong?
Photo of Dennis
  • 196,478 Points 100k badge 2x thumb
So you are able to log in to your icloud account? Can you also log into your itunes account?
If not then there is something wrong with your apple account.
If yes then I would go to an apple store to fix it
Photo of mike
mike
I can log into all my accounts no problem still not working I even created a new apple Id and still nothing
Photo of Dennis
Take it to the apple store
Photo of Robert
Robert, Mobile Master
  • 107,614 Points 100k badge 2x thumb
Are you trying to activate it through your e-mail or your phone number? Bcasue you have different options.
Photo of mike
mike
I dont get the option to use a phone number
Photo of Dennis
Wait... can your phone make calls and text regularly? The phone number to do iMessage should be the default
Photo of mike
mike
Yes my phone works normally but I can't choose a phone number for iMessages or facetime
Photo of Dennis
Go to an apple store to check it out
Photo of Jorden
Jorden, Mobile Master
  • 33,404 Points 20k badge 2x thumb
As everyones been saying the best thing to do is contact Apple.
BUT they also have this handy support document for this very situation :)
http://support.apple.com/kb/TS4268
