Exchanging phones
I have a Samsung which still isn't fully paid out... My dad is giving me his old iPhone 4S so do I have to first pay out my Samsung before I can switch to the iPhone? And how do I swap phones but keep the same number? And it is a rogers iPhone.
Photo of Niamh Darby
Niamh Darby
  • 134 Points 100 badge 2x thumb
Photo of Daniel Kim
Daniel Kim, Mobile Master
Just pop your old sim into the Iphone 4S, if the sim is a different size you can purchase one for 10$, this way you keep your number, you would still be paying off the tab while using the iPhone if that makes sense. :)
Edit: the iPhone 4s would have to be unlocked
Niamh Darby
Thanks so much!
Photo of Daniel Kim
if you see a good answer, click the star! You're welcome :)
keep in mind the iPhone would have to be unlocked in case you didn't see that part.
Niamh Darby
Haha thanks! And yes I'm going to go do that asap :)
Photo of Ivan
Ivan, Mobile Master
If your father is still with Rogers, get it unlocked through Rogers. It's $50 that way versus $100+ otherwise.
Photo of FFS
FFS
  • 564 Points 500 badge 2x thumb
Unlock the Rogers device and swap SIM's through Self Serve or if it is the same size simply swap the SIM from device to device.
