Error in re-receiving same message periodically.
I seem to be having an error with my phone's basic sms messaging. Whenever i receive a message from anybody (including contacts) it keeps re-receiving the message for about a dozen times. Eventually this stops but till then the same message is received every 5-6 minutes.
Can anyone enlighten me on this particular problem, if familiar with it.
Thank you very much.
Photo of Andrei Petcu
Andrei Petcu
Posted 3 years ago
Photo of RudyW
RudyW
That's pretty unique. Never heard of it before. Maybe start with a reset of your phone. If that doesn't work koodo will have to reset your account at the network level.
Photo of Dennis
Dennis, Mobile Master
  • 196,652 Points 100k badge 2x thumb
How is the reception in your area. It seem the network is not getting a confirmation that you have received the message and is trying to keep sending it to you?
Try removing the battery and sim for a few mins and trying again
Photo of Yannick
Yannick
Hi Andrei, if the solution offered by Dennis doesn't work, give us a call and we'll have a look into it :) We can be reached at 1-866-995-6636 from another phone, option #6 for technical assistance. Thank you!
________________________
