easy roam with a plan that has unlimited Canada-wide anytime minutes, unlimited messaging (text & picture)
  • 2
  • Updated 4 months ago
Hello, I live in Canada and I will be going on an 11 week holiday and traveling through 4  countries, Ireland, Scotland, Norway and Iceland. I plan on using easy roam international.  I understand the $10/day use fee and the $100/billing cycle cap.  I believe that I will have access to the same plan that I have here in Canada but my plan has unlimited "Canada-wide" anytime minutes.  Does this mean that I will have unlimited anytime minutes in which ever country I will be in at the time or is it only unlimited anytime minutes to Canada?  I also have unlimited Canada-wide Family calling and unlimited messaging (text and picture) will I still have these?
Photo of Nic D
Nic D
  • unsure and silly
Posted 4 months ago
  • 2
Photo of Goran
Goran, Mobile Master
  • 97,308 Points 50k badge 2x thumb
You'll have unlimited talk and text as normal:
https://www.koodomobile.com/help/easy...
Photo of Dinh
Dinh, Mobile Master
  • 41,784 Points 20k badge 2x thumb
@Nic: if you are using easyroam, you will get unlimited minutes and text from your plan as well as local roaming country.
"Phone calls to numbers in Canada and your current country are included. "
Photo of Nic D
Nic D
Thank you Goran and Dinh.  Just to make sure I understand - I will have unlimited minutes in each of the countries I visit while I'm on easy roam and I will have unlimited minutes to my home country Canada? That sounds too good to be true.
Photo of Dinh
Dinh, Mobile Master
@Nic: Well, it is true. If your plan has data, you could use your data from your plan while roaming also (with easyroam)
Photo of Nic D
Nic D
Yes I do have 2 GB.  Thank you very much for your help.  It was the "Canada-Wide" that had me stumped.
Photo of Dennis
Dennis, Mobile Master
  • 196,120 Points 100k badge 2x thumb
If you think wifi will be sparse during your travel, you might want to up your plan.  Your monthly plan might be more, but the easy roam will still cost the same
