easier way to check on airtime usage ?
  • Updated 3 weeks ago
  • (Edited)
I know we have shock free for data, so what's an easy way to check on your airtime usage during the month to see if you are reaching your limit: the usage page in selfserve doesn't seem to distinguish between calls made during unlimited calling periods and calls made during other hours (ie the ones where you could eventually go over your limit). To figure it out you'd have to sit and do a bunch of addition (who has the time?? = not an option). Is it a passive way for the company to profit? Am I missing an easier way? Thanks!
Photo of wondering
wondering
  • 82 Points 75 badge 2x thumb
Posted 1 month ago
Photo of Mats
Mats
  • 8,286 Points 5k badge 2x thumb
I dont have limited minutes so I cant check but on the usage page it doesnt show how many minutes you've used out of what you have? For instance on my usage page it shows my data and will give me how much ive used/out of what I have total. Air time shows how much Ive used/unlimited.
Photo of Luis
Luis
  • 216 Points 100 badge 2x thumb
My plan includes 500 min, 1gb.
On Self Serve Usage tab (web version), I have 3 columns.  Data, Messaging, Airtime.
In the Airtime column, it shows usage in a circle and underneath '/500 minutes'.
Photo of wondering
wondering
Thanks- I’ll check that out !
