Dropping home wifi
I know now why my data usages is over the limit. The wifi keeps dropping off. I just bought a new Samsung S4 and thought that my old S3 was the problem. Is it a router problem or a S4 problem? There seams to be lots of discussions on the S4 having connection holding problems.
Photo of lsg.bs2
  • 200 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Jonathan I
Jonathan I, Mobile Master
Well that seems like an issue with your router since it's happening to 2 different devices. Do any other devices in your house have issues connecting?
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 193,200 Points 100k badge 2x thumb
Go into your wifi settings and make sure smart network switch or download booster are not on, these use a combination of cellular data and wifi to boost download speeds. Also in the advanced settings within the wifi settings make sure you have the "Keep wifi on during sleep" set to Always.
Photo of BobTheElectrician
  • 57,518 Points 50k badge 2x thumb
Some router / Samsung combinations don't play nice together. Follow Paul's suggestions on the cell phone side.
When it comers to the router, if yours is a dual-frequency type, limit it to one frequency only. Give your Samsung a reserved IP address, and if the router supports QOS, give the Samsung priority.
See rickster’s post on how to limit spurious data usage on this page:
Data enabler widget and Play Store setting can save your grocery money.
