Dropped calls and bad reception
  • Updated 2 years ago
Just in the last week my iPhone has had awful reception (lots of static) and has dropped several calls. I work from home and all of these calls are from my office. I have the latest update for IOS 10.2 and my phone is a 5s with a small tab plan. Nothing has changed, it just simply started doing this. I'm in Kelowna within the Benvoulin/Sprinfield area. Not sure if there is a phone setting or know reception issue in my area. Anybody who can add a suggestion or possible solution would be greatly appreciated.
Photo of Dave Meaden
Dave Meaden
  • 150 Points 100 badge 2x thumb
Posted 2 years ago
Photo of David
David, Mobile Master
  • 93,460 Points 50k badge 2x thumb
What happens when you move from your home to another location, either down the block, or downtown?
Dave Meaden
Thanks, I will check that out in the next day and get back to you.
Dave Meaden
Signal is good downtown. So I brought the phone to the Koodo kiosk and just traded up for a new phone as the Apple store told me the phone is most likely pooched from 3 years use. So I get the new phone home and make my first call and guess what...the call dropped! So this is telling me there is a definite signal issue. I run a business and this is not good for obvious reasons. Any idea how to resolve this?
Photo of Sophia
Sophia, Mobile Master
  • 142,934 Points 100k badge 2x thumb
Sadly, if you're living in a spot with poor coverage, there isn't much you can do about it. Bell, Telus and all subsidiaries all share the same towers. All you can do is check if Rogers/Fido have better coverage and if not, you might need to go back to a landline.
Try other locations in the house, such as near a window, or move from the east of the house to the west, etc.
Dave Meaden
It is strange that for 3 years in the exact same spot the phone signal was fine, no dropped calls ever. Then this last week practically all calls drop. If Koodo can't resolve this then it's good bye Koodo.
Photo of David
  • 93,228 Points 50k badge 2x thumb
It is possible a tower is out and your neighbourhood is most affected.
Dave Meaden
It's possible. So how do you find out? Does Koodo have actual technical support? Or do I call Telus?
Photo of Ivan
Ivan, Mobile Master
You'd contact Koodo's support.
