DOUBLE minutes plan
  • Doesn't Need an Answer
Hi I wonder if with the deal on Double minutes etc , could someone advise me if a switch to that plan would lower my monthly billing please. I am on a budget . thank you
Photo of Rosemarie Harvey
Rosemarie Harvey
Photo of Camilo_A
  • 30,198 Points 20k badge 2x thumb
Hi there... Well it really depends on many factors... Are you going over your minutes every month? if the answer is yes, well, taking one of those plans with double minutes will help you a lot.
On the other hand, remember that you have your Self Serve account 24/7 to check your minutes so you do not go over, when clients have a higher bill, most likely is because they have the wrong plan and the minutes or features are not monitored...
I really don't see why you should not change to get more for the same price, this will help you out to have a steady bill, btw, what is the plan you currently have?
