Double Canada wide plans issue
So I signed up for the 45$ canada wide data plan last month, this billing cycle is only for this plan.
I've had some confusing events which I'm not sure what to make of.
2 days ago I got a notification stating I had use 75% of my data. Think this was odd since I know I hadn't used 750mb so far this cycle, I check self serve which shows I've only used 400MB of 1524MB.
Ok so the notification was wrong, likely sent out from the previous limit of 500MB. but how did I get the extra 500MB(1524MB instead of the 1GB)?
I'm not complaining if Koodo wants to give me a extra 500MB a month, but I don't need to get charged for it. Which I'm not sure if this will happen yet as billing cycle still has a few day left.
Anyone else have this oddity of a possible explanation ?
Oh and I have 2 lines on the same plan and both are showing the 1.5GB, not sure if the 2nd line got a notification for getting close to the limit though.
Photo of Boolanger
  • 9,234 Points 5k badge 2x thumb
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 136,982 Points 100k badge 2x thumb
sounds like the plan was switched mid billing cycle. Data doesn't get prorated so you would have 500 MB under the old plan and 1 GB (1024 MB) under the doubled version for a total of 1524 MB.
