Double charging
  • 2
  • Updated 7 months ago
Why do I get double-charged for the same month? September was supposed to be my first full month, which was charged in my first bill, and now there's another bill for the same September cycle. How come?
Photo of An Truong
An Truong
  • 80 Points 75 badge 2x thumb
Posted 7 months ago
  • 2
Photo of David
David, Mobile Master
  • 89,014 Points 50k badge 2x thumb
Did you make any changes to your account such as porting in a number, etc?  If so, there will be an adjustment on your bill with both additional charges, and a refund amount. You can post your PDF bill here with personal information removed and the regulars will try to help you interpret the bill.
If this is your first month, please review this link
Photo of Ranjan
Ranjan, Official Rep
  • 28,608 Points 20k badge 2x thumb
Hi An - payment for your first bill was received (thank you!). The new bill only shows charges for the current month (Oct. 7 - Nov. 6). Where do you see that you're being charged twice?
Photo of S F
S F
Hi An, I guess you are seeing it as double-charged when you are looking at Self Serve-> Billing. But if you download the bill in .pdf then you would see the charge was actually for the upcoming billing cycle. I believe that's a minor glitch at UI level in Self serve. Probably @Ranjan can concur to this, and log this to the appropriate team for fix.
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
Sometimes, you received your bill notification sooner than self serve E-bill is updated.
Give a day or two and log into self serve again. You will see your actual E-bill then.
Photo of S F
S F
Mayumi, this bill date was on Oct 7. so logging today which is well above 1-2 days, is still showing as double charge for same month outside in the Billing menu, but actual pdf has it split up clearly for next cycle. i.e.Oct 7-Nov6
Photo of Mayumi
So, do you see another charge of Sep 7 to Oct 6 on the PDF again?
If not, then you didn't get double charged.
You usually receive your bill notification 3 - 5 business days after the billing date.
Oct 9th was holiday. So if your bill date is 7th, then it's still early to updated everything for this month's billing.
