If i sign up for the double plan and stay with you guy for 2 years. Is that plan stay in effect for all two years?
Photo of Trung Nguyen
Trung Nguyen
Photo of Ahmad
  • 96,062 Points 50k badge 2x thumb
You will be able to keep the same plan until you change your plan or cancel. So the answer is yes. As long as you keep it, it won't go away and Koodo won't force you off it
