Don't have data block but data is not working. I used 265 mb and I have 2 gb data
  • Updated 6 months ago
Photo of charmaine Galicia
charmaine Galicia
  • 160 Points 100 badge 2x thumb
Posted 6 months ago
charmaine Galicia
Can't send and receive mms and online search
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
Is your data enabled in the phones settings or quick toggles in the status pull down?
Go to settings - connections - data usage and make sure its checked off to enable data.
charmaine Galicia
Didn't work
Photo of Bernard
Bernard, Official Rep
  • 75,560 Points 50k badge 2x thumb
Everything is ok with your Charmaine. Looks you have your own phone (not a koodo one) and I suspect the issue may be with that. Not to worry though, we found that resetting your phone solves 80% of the issue. If you haven't yet, turn your phone off, take battery out if you can and reassemble. Let's see if that helps.
Photo of Dinh
Dinh, Mobile Master
  • 32,732 Points 20k badge 2x thumb
okay,
When you said your mobile data didn't work, did your wifi was on and connected also?
Photo of Dinh
Dinh, Mobile Master
okay,
When you said your mobile data didn't work, was your wifi  on and connected also?
charmaine Galicia
My wifi is off. Do you think it's my phone? I might try to insert other sim on my phone to try if it's working
Photo of Dinh
Dinh, Mobile Master
yes if you can, it will eliminate the network factor if other phone works.
Sometimes, taking  the sim out and putting it back could also help.
charmaine Galicia
I did took out the sim one time but it didn't work too i'm getting frustrated
Photo of Dennis
Dennis, Mobile Master
  • 187,168 Points 100k badge 2x thumb
Photo of Raine Galicia
Raine Galicia
I finally figure it out. thanks
Photo of Allan
Allan, Mobile Master
  • 56,446 Points 50k badge 2x thumb
What ended up being the issue?
Raine Galicia
My phone
Photo of Mathieu
Mathieu, Mobile Master
  • 60,828 Points 50k badge 2x thumb
What did you do to fix it?
